Status
Not open for further replies.
1 - 4 of 4 Posts
Just had this start happening today. I can only use one tuner at a time. If I am recording and use the other tuner to try to watch something I get crazy screen distortion and then it pops up telling me my access card has expired yet the other tuner is working fine. I ran all systems tests and everthing checks out and I got strong signals to both tuners from that test as well.
Now I find if I try to watch anything recorded in the myshows area the recordings are playing back with video distortion as well. Audio is fine.
I watch one tuner and call up PIP and the second tuner distorts and goes to the access card expired screen.
So right now all I have is a single tuner DirecTV receiver as the functions beyond use one tuner are screwed up.
I just did do the unplug routine and will see if that resets/clears the problem. Be back in 1/2 hour to let you know.
Argee
Discussion Starter · #2 ·
OK back and the unplug for 15/20 minutes did the trick. I guess these things need to be rebooted now and then.
Argee
Mine has not been unpluged or turned off since April. No issues.
Sounds like something else might be wrong there.
Ed
I had the same problem, and it was a bad multi-switch. I returned it and got a new one (Sony) and have had no problems since June.
1 - 4 of 4 Posts
Status
