1 - 4 of 4 Posts
I have programed my RCAP05B setup button for my Yamaha RX-V465 AVR
I have just the setup the AVR will display speaker however I can't change any value w/ the direction button.
I want to be able to set the speakers up example large small none phantomcenter ect.
any tips is appreciated.
STB
Please continue this line of questioning in your original thread HERE where all the answers have already been posted.
But I have to ask why you continue to use the RCA if you have at least two Harmonys? Couldn't you learn the commands in question from Harmony?
Discussion Starter · #3 ·
Hello Dave this other old thread was only to turn on and off the AVR.
Current problem is unrelated. here's a link.
I'm planning on getting a center channel speaker and will need to be able to turn it on it's currently set to off when I had the 300 w/ my harmony software I was able to adjust speakers not the case w/ this RCA or the 700.
http://www.avsforum.com/avs-vb/showthread.php?t=1333327
Discussion Starter · #4 ·
Hello Dave I resolved my speaker setup adjusting values.
I accidently found a soft enter button on my 700. the soft button works and the
OK button inbetween the directional buttons no work.
I may mess around w/ customize buttons advanced however I'm leary of too many reflashes, this remote is now locking up on help only reamedy is to remove the batterys.
then I believe the update doe'snt get saved correctly.
1 - 4 of 4 Posts
