I would build (or have a pro build) an equipment rack to the rear of the room. It could either be recessed into the wall or built out. You Can build a cooling system for it, or buy the type used for computer servers that have cooling systems. You could have an electrician wire a dedicated 30 AMP circuit to your amp/equipment rack to give it plenty of juice (which achieve your goal to re-route your power to where you want it as well). Then use a Xantech wired IR repeater system to control all the hidden equipment that is in your rack. You will then not see distracting LED and LCD lights, just see the film and your equipment will stay cool.
