1 - 4 of 4 Posts
I have downloaded WINisd and designed an enclosure, but I'm not sure if i have everything entered correctly. I will be using 2 Eclipse 8810.6 car subs to experiment with on this first build. If I list the t/s parameters, will someone run them in WINisd for me. My result called for a 5.998 vented enclosure. Just want to double check before i start making saw dust!
Discussion Starter · #3 ·
correct. when i entered all of the info i ended up with about 6cu ft. not sure about the tuning. here's the info:
living room size: 17'x22' ceiling goes from 8'6" to 16'
second floor has an open loft and the kitchen is open and behind the living room
woofers: 10" aluminum single voice coil (6ohm) x2
qts: .41
qes: .511
qms: 2.139
fs: 22hz
vas: 2.94cu ft
spl: 84.7db
sd: .0357sq/m
thanks!
1 - 4 of 4 Posts
