When using receiver test tones of pink noise, or the Avia et al, you're sending a broad range of requencies to the sub, right?
So, when setting the sub's level, you're setting the "average level"? Now, do all you experts here really accept this sub "average" as the calibrated level? If so, then depending on the low end reach of our subs, freqs like 25Hz to 30Hz will be much below the 75dB calibrated level.
Or do y'all try to get more of the low end of the sub to the reference level, at the expense of having excessive bass at, say, 40 Hz?
