This is my first post - thank god I found this site as I was about 1 day away from getting a BOSE AM10 and all of your posts saved me on that one.
Now after much researching and searching on the forums, I have narrowed it down to the following Systems:
- Orb Audio - People's Choice (Orb2 Fronts / Orb 1 Rears)
- Polk 6880
- Mirage Nano Stat
- Klipsch Quintet III w/ Klipsch Sub
I have a H/K 340 Reciever (approx. 50-55W) and the room has hardwood floors with dimensions of 12' Deep x 25' Wide with 18' ceilings for about 15' of the Width. I will be using it for HT about 70% of the time and 30% for music. I already have spots for the speakers but only have about 10" H x 6" W x 6" D Max dimensions for the satellites (hence the choices above). The max budget with sub is $1000.
I have not heard any of these systems in person apart from the Quintets, and will not likely be able to hear the other three in person. Based on the room setup, usage, and choices above, what do you guys think my best choice is. I was planning on doing the Orb's, but many of the other choices may offer similar sound for the less $$$. Also, are there any concern's on room size being a problem with these.
Thanks in advance - this forum is really great!
Chris
- Polk 6880
- Mirage Nano Stat
Chris
