1 - 4 of 4 Posts
I am really new with these setups but I have a mounting Question please.
I just purchased a Sharp AQUOS LC32LE700UN
I already have one of these
http://www.amazon.com/gp/product/B00...ef=oss_product
and I bought this adapter for it
My issue is that the plates all fit but I have NO scres that will fit the VESA holes in the TV, and worse yet it appears anything that would fit in the holes would NOt fit through the adapter plate
Im getting frustrated if anyone can assist with ewhat I need. thanks in advance
Manual says...
This TV should be mounted on the wall only with the wall mount bracket AN-37AG5 (SHARP). The use of other
wall mount brackets may result in an unstable installation and may cause serious injuries.
• Installing the TV requires special skill that should only be performed by qualifi ed service personnel. Customers
should not attempt to do the work themselves. SHARP bears no responsibility for improper mounting or
mounting that results in accident or injury.
Seems like the adapter plate you got is not compatible with the TV.
1 - 4 of 4 Posts
