also if it helps, im pretty much just looking for any good indoor HDTV antenna under $50. so if these arent the best, and there is something cheaper, please do tell
i also need an A/B switch because i only have 1 RF input on my tv, but i also have cable. i would guess that wont cost me much any and all help would be great. |
Originally Posted by mterzich If you only have one RF input on your TV, you probably don't have a digital tuner. Also since you did not pick up the HD channels (Fox, NBC, CBS, and ABC with channels such as 2.1, 4.1, 5.1 and 7.1) when you scanned the cable, that also indicates that you probably don't have a built in digital tuner. Most TVs with a digital tuner have two RF inputs, one for analog and the other for digital. Without a digital tuner, you would probably have to get a HD cable box for HD cable reception. At first I thought that you could purchase an external digital HD tuner for OTA or cable reception but I don't think that will work since I believe that will convert the digital signals to anolog channel 2 or 3 which is not HD. Does anyone know if there is a external digital HD tuner that will convert the signal to Component output? |
Originally Posted by mterzich Which model do you have? If you give me that information, I'll check to see if it includes a digital tuner. Generally only the more expensive TVs have a built in digital tuner. Even some of the 42" or larger sets don't have a digital tuner. Normally the cable companies broadcast the local national networks unencrypted on the cable so most people that have a digital tuner will receive that channels. |
Originally Posted by mterzich Unfortunately, without a digital tuner, you cannot pickup digital stations. |
Originally Posted by cseoni Zenith Silver Sensor from Sears for under 25 bucks....hands down! I have used it for 9 months without a single problem... |
Originally Posted by mterzich The cheapest HD tuner with Component output that I could find on is about $250. |
