Rear Center height and distance apart - need help ASAP!!
1006 Views 1 Reply 2 Participants Last post by  larryep
I need to tell my contractor within the hour what distance apart to place the rear centers in a 7.1 set up. Does anyone know? Thanks!!!
1 - 2 of 2 Posts
Any info on type of speakers (bipolar.etc?)
Here is atypical setup for 7.1
7.1 Channel Setup
Again the introduction of another satellite speaker is required when using the 7.1 speaker. This system gets rid of the centre rear speaker and replaces it with two rear surround speakers. Like the 6.1 system the rear speakers use a balancing of the surround channels to create the right effect. This time however it is more complex and more difficult to get the speakers in the correct position. Most 7.1 capable sound cards come with tweaking utilities to help you get the balance right from all your speakers.
[/URL] [/IMG]
See less See more
1 - 2 of 2 Posts
