1 - 2 of 2 Posts
Discussion Starter #1
I am a Home Automation guy, and have a customer that needs a new Rear Projection Projector. He had some JVC piece that was about 4 years old before the bulb exploded and melted the insides.
Who make a $2500-5000 proce range projector 1080p that sets up nicely and will replace teh JVC. I'm relatively new to the projector world. So excusee my lack of knowledge.
Do you want to set up a rear projector or are you looking at a front projection application? The projectors are essentially identical, however the set-up and screen material will be drastically different. If you go the rear projection route a short throw projector would be helpful.
1 - 2 of 2 Posts
