1 - 5 of 5 Posts
I think I have my front 3 and subwoofer narrowed down to these from The Speaker Company:
http://www.thespeakercompany.com/LCR...ers-P40C6.aspx
http://www.thespeakercompany.com/ASW...er-P62C17.aspx
Now I need to decide on the rear 4. I Could get 4 more of the same bookshelves, but they are not exactly small and I would like to be able to put the rears on stands that I can move when not in use (small kids).
I have no stands for either, but ones for small satellites would seem much smaller/easier to move around, but if the sound difference is quite large I might go the bookshelf route.
What 4 rear satellites would be good for these speakers?
Discussion Starter · #3 ·
That's funny...I was just looking at those. They were originally only available in white, but according to the website blog they should start getting black ones this Tuesday.
Will it make much of a difference that they are a different series?
I wouldn't sweat the difference in series for the rears. They don't carry THAT much of the load and after you run auto setup, I would think you'd be OK.
If not, you have 30 days to change your mind given their return policy.
1 - 5 of 5 Posts
