Status
Not open for further replies.
1 - 7 of 7 Posts
Discussion Starter · #4 ·
Originally posted by russwong
My understanding is, depending on what you plan to use the system for, it would be either center or front.
Watch movies.
I would go with the rear surrounds over the center for now...if you do plan on getting a center eventually. The front speakers can do a pretty decent job of handling the center channel data for now.
I am in a similar position and deciding whether to add the surrounds now or the sub. I am a bass lover so more than likely I will go with the sub and just have my 2.1 setup for now :)
In that case upgrade the center channel first. Yeah, surrounds are important, but the amount of sound being produced by the rear channels relative to the center channel makes upgrading the rears first seem kind of illogical to me.
1 - 7 of 7 Posts
Status
