I have a small (11'-5" wide x 13'-5" deep with 8' ceiling) room. I have base traps in the corners and I have 12-2'x4'x3" thick sound panels on the walls. The sub that I currently have in this room is an old left over NHT SW2P. The NHT is a (external)16" x 16" x 16" cube with separate 80 wpc amp. I am wanting more bass, more impact, but with the current economy I want to keep costs down as much as posable. Building something is not a problem, I have all of the tools needed, but as I said I want to spend as little as posable. I was thinking about refitting this box with a new driver and replace the amp. For the driver I was thinking something along the lines of this: www.parts-express.com/pe/showdetl.cfm?Partnumber=297-460 . For the amp I could use a plate amp or an EP2500. If I reused the existing NHT box I probably would want to plug the port off. I like a sealed sub.
I have not used any of the programs to calculate box size needed, nor have I opened up the NHT to see how well (braced) the box is. Has anybody rebuilt an HNT before? Would I be better off building a whole new sub using a larger cheaper driver along the lines of this: www.parts-express.com/pe/showdetl.cfm?Partnumber=295-468 ? What do you guys think?
