I'm going to be helping a friend redo his theater room to fix a few problems in the original design. The room is 18' by 12'. The room is open to a very large game room. One of the biggest problems is that the 12' wall behind the seating position is just a layer of drywall with the other side of the wall being an unfinished storage room. The room also has to 4' wall's that separate the theater room from the game room that are hollow. When playing music, these wall's noticeable vibrate at fairly low listening levels.
Also, the ceiling is hollow with an air duct running down the middle of it.
The plain is to put drywall on the wall in the storage room and fill it with insulation. We are also going to cut holes in the top of the 2, 4'ft walls and blow in insulation. We also want to build the 4ft walls out and narrow the distance between them from 10'ft to 6'ft and put in a solid wood french door.
Also, we are thinking of putting in a new ceiling underneath the existing one and insulating it. The idea for the ceiling is to have it start 10" lower than the existing ceiling on the 18'ft sides and have it tapper to 5" in the middle of the room. Not sure if this is a good idea or would make any difference.
After the room is done, he would want to build/buy some bass traps for the corners and some other room treatments.
I was hoping some people here would give some feedback and add some suggestions on what we should do and what treatments would work best. Here is a rough draft of the starting room.
