1 - 2 of 2 Posts
Basically I want to build a giant outdoor screen but I'm not sure what size would be best. 2x4's come in 8ft 10ft 12ft and 16ft. I'm thinking of going with the 10ft as the base width using projector central for the measurments. Look at my plans and let me know what you think?
Always what kinda of super cheap material should I use for rear projection so we can play rock band in front of it?
I built a 2x4 frame for mine and it works great. I used four 16-footers and they are joined with 'L' brackets.
I believe trapeze fabric is the most recommended fabric for rear-projection. Apparently it costs about the same as BOC.
1 - 2 of 2 Posts
