I assume the back of the cabinet is open, is that correct?
Sent from my SM-G965U using Tapatalk
I assume the back of the cabinet is open, is that correct?Hello,
My Yamaha RX-A760 is about 2 years old and in a fairly tight cabinet. I can feel the heat radiating out of the cabinet and on the top of it. I need additional cooling.
I bought this fan to help: Size: 4.7 x 4.7 x 1 in. | Airflow: 65 CFM | Noise: 18 dBA |. I have space (about 2.5"W x 7"H) to place it upright to the left of the receiver where it is vented. There is not enough room above the receiver to place this fan. My questions are:
Should this be sufficient in assisting the built in fan? And,
Should the fan be blowing air in or extracting air out of the receiver to assist with cooling?
Because this is my first post, it won't allow me to attach a picture of my setup or a link to the fan.
Volksball
These work really well and are inexpensive and relatively easy to install.Only with a hole for wiring.
Thanks for replying.
V
Yes I have an Aircom T9 right on top of my Denon 6500 and 2 Airplate T9 in use. One at the bottom drawing cool air into my AV rack and one exhausting hot air at the top.Thanks for posting that. Yeah, I've seen those. The issue here is, cutting into my cabinet. I'm looking for a quick, but effective solution, if there is one. If not, that would be my next step.
Based on your recommendation, you then would suggest that the fan extracts the air, rather than blowing into the receiver?
V
Ok. Thanks. On top isn't really an option, so I'm trying to find out the best workable solution. I'm open to installing one of the fans on the side of the cabinet, but trying my best to avoid carving it up if I can help it.If it fits on top of your receiver get the one that blows air out the front, either the s10 or T10. It looks pretty tight in there though.
Honestly I would put the AVR on top of the cabinet but maybe that's not an option for you.
Ah ok. Good to know. I've got to figure something out quick, then. Thanks.That environment will shorten a units lifespan. If the back already has a hole, either make it bigger or cut the whole back out.
I learned that the hard way as well on one of my first Onkyo receivers that only lasted 18 months luckily it was under warranty but ever since then I always make sure I have some type of fan pulling air outI had an A760 that I bought for a friend. she had it in the cabinet with little ventilation. Eventually the HDMI board went out and had to be replaced. since then she leaves the cabinet doors open and everything works fine.
AVRs need ventilation badly or it shortens their life greatly.
You will have to cut the back of the cabinet! I didn't want to either but realized it's either aesthetics, or a receiver burning up because of the excess heat. You don't have to cut a lot just enough to exhaust the hot air inside. My Infinity worked much better after I made a larger hole. Is it only you that doesn't want to cut the hole, or a significant other complaining?Ah ok. Good to know. I've got to figure something out quick, then. Thanks.
The latter will likely happen.You will have to cut the back of the cabinet! I didn't want to either but realized it's either aesthetics, or a receiver burning up because of the excess heat. You don't have to cut a lot just enough to exhaust the hot air inside. My Infinity worked much better after I made a larger hole. Is it only you that doesn't want to cut the hole, or a significant other complaining?
Every HT enthusiast has made mistakes in our chosen hobby. Some of us bigger than others. Thank you being humble enough to ask for help. 99.9% of us are here to help.Thank you, Scott, for your good advice. I'll make that work.
And thanks for your condescension, Dono. Hopefully someone "enlightens" you soon. If I had all the answers, there wouldnt be a reason for me to post here. Hopefully your questions are met with the same level of helpfulness and understanding.
V.
