1 - 20 of 20 Posts
· Registered
I'm working on a theater room and have most everything other than the receiver picked out. My room 14'4" X 12'. Components are:
- Paradigm CC390 Center Channel
- Paradigm Monitor 9 Fronts
- Paradigm ADP390 surrounds
The speakers can obviously handle a lot of power (200 watts), but they obviously won't need to be fully utilized in a room my size. I do however like loud movies!
I'm considering the following receivers (want to stay under $1k)
- Onkyo 806
- Integra DTR 30.1
- Yamaha RX-V3800
I'd appreciate input on these and any others you'd reccomend. I have a PS3, blu-ray, and Dish HD.
Thanks in advance!!
· Registered
- Onkyo 806
- Integra DTR 30.1
- Yamaha RX-V3800
Thanks in advance!!
The 806 is a good choice, might check to see if you can find an 876 in your price range, big jump in performance.
· Registered
Yea, I managed to get an 876 (refurb) from shoponkyo.com for under $1k, so it definitely can be done.
· Registered
Discussion Starter · #4 ·
Are the problems with the Onkyo (particularly 806) overblown? I hear a lot of how it was a downgrade from the 805, has the blue dots problem, etc. That was my only fear in going with the Onkyo.
I was actually leaning toward the Integra, but considering the speakers wasn't sure if 90 watts per channel would cause lesser quality at louder volumes.
Thanks again!
· Registered
Thanks again!
I have heard of issues with the 806 but I have not owned one. You could check the 806 owners thread to see what issues there might be. I would suggest the refurbed 876 in silver which is available on shoponkyo for $100.00 less than your maximum budget. Just so you know to get the lowest price at shoponkyo you have to join Club Onkyo which is free
Bill
· Registered
A refurb unit would come with the newest firmware updates. Problems were solved with the 805, 806 that I know of this way. I personally have an 805 and stole it by buying a refurb from shoponkyo.com.
If I had your budget I would of went with the 875. With the downgrade from the 805 to 806 it makes the choice even easier. The differences between the 876 and 806 are greater than the previous year. The HQV Reon chip in the 876 is awesome, Audyssey Multi EQ XT, A much better power section (nice for 4 ohm or hard to drive speakers), etc.
The Pioneer SC-05/07 discounts are also great and they are nice AVRs.
· Registered
Discussion Starter · #8 ·
Thanks for the replies. Now I'm leaning toward the 875. I did some quick searching around (granted, not a ton) for the Pioneer, but was unable to find it. Does anyone know where you might find them from reputable dealers (preferably authorized sellers)?
· Registered
AC4Less has
Marantz SR8001 $699
Marantz SR8002 $1099
Onkyo 875 $749
I would go for either of the Marantz
· Registered
The 876 is fine too. That model didn't change from the 875, they added features but kept the good stuff intact.
· The Village Idiot
The 875 can be had here - or get the 876 here - you'll need to join ShopOnkyo to get the best price (silver - $899.00) - the suggested Marantz 8001-2 are both fine AVRs as well.
· Registered
Discussion Starter · #12 ·
And I take it all of those receivers would have plenty of power to run my speakers? Is there a minimum wattage I should look for?
I had heard somewhere that Marantz wasn't all that great at mids. It was from a guy trying to sell Integra though... false information?
· Registered
In my mind, receivers at that level are pretty comparable. You can look at online benchmark tests for receivers in this price range to see what I mean.
Ultimately, the power supply transformer seems to put the biggest limitations on output power.
The Pioneer SC-07 that someone suggested might out out a bit more power because it's class D design is more efficient.
I should note that Onkyo has put up some nice numbers on some of the benchmarks I have seen. I have to say I am impressed. Not that I think Yamaha is inadequate, but you can't deny that Onkyo is a nice bang for the buck. I just prefer Yamaha as I am familiar with the product.
One thing to note is that your rapidly hit the law of diminishing returns for output power. That's because it takes double the power for a 3 dB gain. So unless you look at a benchmark and see double the power from one to another receiver, don't expect big differences in max SPL.
Really, for movies at reasonable volumes in reasonable rooms with reasonable speakers (sorry) you should expect great results, IMO. The only receivers I don't like are the budget models because they are sometimes pretty weak (like 30 watts / channel all channels driven.)
· Registered
Well, I have not measured all these receivers myself. But based on benchmarks I have seen, receivers in the price class should be pretty comparable, power-wise.
Some might work better with lower impedance speakers, or speakers with impedance dips. That's common thinking, anyways
Actual tests are uncommon
· Registered
Originally Posted by Marbury021 /forum/post/16947058
So now i see the Denon AVR-989 for a great price. Is this a comparable receiver? Specs look great and looking through the threads, I couldn't find any significant problems.
Thoughts?
That AVR is comparable to anything in your price range. Seems to be loaded with features and has plenty of power.
· Registered
Discussion Starter · #18 ·
Thanks for the reply! I pulled the trigger. I have read that it can only convert video passed through analog. Will that adversely affect me if I hook up my Wii? Everything else will be HDMI, so no worries there!
· Registered
Isn't your WII analog? No problems because that is what you need this AVR to do anyway. Good luck and hope everything works as you want.
· Registered
- Onkyo 806
- Integra DTR 30.1
- Yamaha RX-V3800
Thanks in advance!!
just sent u a pm...
alan
1 - 20 of 20 Posts
