Are the cables to the sub fixed? What kind of connection is it, and are there any other input ports? It would seem a much better idea to just get the right kind of cable to connect from receiver to sub, even if it means a funny cable (like a Y cable, or otherwise unmatched ends). Or if the cable is fixed to the sub, you could adapt that cable rather than cut/solder).
Originally posted by DoubleO Right now I have a set of boston computer speakers that plug into my SB audigy sound card, and I was wondering if I could cut the ends off of my boston sub and two of the speakers to use with the the XR-50. |
