For a lot of reasons I won’t bother to enumerate here, I will probably end up using a receiver instead of separates for a 7.1 system. What I’d like to eventually do is add a dedicated 2ch preamp with a HT bypass plus a separate amp (or monoblocks) for the mains. Is such a setup possible?
From reading the 2ch forum, I realize a lot of folks are using a pre/pro such as the Integra 9.8 in such a manner, but I’m wondering if it’s possible with receivers. If so, exactly what gets connected to what?
Just simply for example purposes, a receiver such as the soon-to-be released Pioneer SC-07 has the following audio inputs and outputs:
1. Zone’s 2 & 3 – Each zone has a pair of RCA outs. Manual says they can be used to connect a second or third amplifier (doesn’t say anything about a pre-amp)
2. Pre-Outs – Pair of RCA’s for Front, Surround, and Surround Back…single RCA each for Sub and Center – Again, manual says they can be used to connect additional amps (nothing about pre-amp).
3. CD-R/Tape (Tape Loop) – Pair of RCA’s out and a pair of RCA’s in. – Manual says to connect source components here.
With all that, it would seem a separate pre-amp w/HT bypass plus separate amps should be able to be connected some kind of way. But never having owned any gear like this before, I’m having a hard time getting my mind wrapped around how to do it. Can anyone help?
