Hi - I have a Sony receiver (DG810) - Has 3 HDMI INputs, 3 Component & 3 Composite Inputs. Each "section" of inputs is labeled the same - SAT in, DVD in, Video 1 in- But what happens is once I connected my 3 HDMI devices to each port - doing that defeated the composite & component Inputs of the same name, and they did NOT function. I found this a little odd - since the receiver basically loses 2/3 of it's connectivity. Is this common amongst most of the other similarly priced receivers brands in the $300 range? Have any of you not had this problem with your receiver? I really need to have receiver which can handle 9 components simultaneously, without all this baloney. Thanks for your help, Deca
