1 - 4 of 4 Posts
So I had my receiver standing on its side after I got a Sony CRT HDTV that took up extra space. After a week, I noticed that something inside of the receiver was making a hum sound. It may have been causing interference on my TV too. Later I moved the receiver to the floor, right side up, and now it doesn't make the noise anymore.
Does anybody have any idea what would be humming inside of my receiver? I thought it wouldn't matter since it is all solid state electronics inside.
Transformers can hum. The changing magnetic field will stress the metal. Generally it's not a problem, but perhaps orienting it the way you did increased the audibility of the vibration.
Discussion Starter · #3 ·
Ok, I was just worried that something was about to blow. I'll try standing it up on the other side.
I did see some discoloration on my TV at the time though. I wonder how large the magnetic field on these transformers are...
If a receiver makes noise standing up on one side, I wouldn't stand it up on the other side, either.
If you're seeing discoloration on your TV, you definitely do not want what's causing the discoloration to be near your TV.
It sounds to me like it's time to find a new equipment stand so that everything fits properly.
1 - 4 of 4 Posts
