My question: should I be worried or make a change?
I've lived in my home for nearly a year now with the same setup but yesterday a problem occurred.
Here's the setup I have powered up on one 15amp household circuit:
This setup worked flawlessly for the past 10 months or so. Yesterday, while the computer was already running I started some music and went and powered on the receiver like I normally do. Volume was set very low. No more than 20 seconds after, the breaker trips and the UPS kicks in. My aging APC RS-1500VA's battery only gave me about 90 seconds to react before completely dying.
Next I went out and purchased a brand new APC BX1500G UPS. I hooked everything up again in the same order and powered on the amp. This time, the breaker did not trip but the UPS registered an "Event". Each time I power on the receiver, the UPS registers an "Event". An event signifies the UPS had to kick in some shape or form. My old BX1500G never registered an event from powering on the receiver.
I then plugged my receiver into a separate GFCI outlet in my kitchen to see if it would trip the outlet, it did not. It worked just fine. And as expected, had no effect on the UPS on the separate circuit.
In my setup, powering on the receiver has always caused my (2) halogen uplights to dim briefly (like the receiver is sucking the power as it kicks on) so it definitely has some effect on the circuit. It just had never caused the breaker to trip.
Should I be worried I am doing damage to my PC or UPS? Is this likely a circuit problem (overloaded or otherwise) or an issue with the receiver's power supply? Did my old UPS just give up after being hammered by the amp turning on for 10 months?
Thank you,
Bryan
- Rotel RSX-1067
- 5 speakers
- 10" subwoofer
- (2) halogen uplights
- (1) standard light bulb
- (1) wireless network router
- (1) APC UPS with the following plugged in and running
- --- PC with SSD and 6 HDD (Intel i7)
- --- (2) LCD Monitors
Thank you,
Bryan
