Long time lurker, first time poster.
I just set up my Comcast Motorola 3412 HDDVR with my Integra receiver. Went through the codes so I could control the TV, Motorola box and receiver with the Motorola remote. All works great except I have to choose between power on or power off on the receiver.
Integra is made by Onkyo so I tried the two codes supplied (both Integra's and Onkyo's codes). If I use one code the power all button turns everything on (box, tv and receiver) but when I try to shut down everything only the receiver stays on. When I use the other code only the TV and box turn on but then everything turns off with the remote.
Has anyone had a similar issue? Any suggestions? Though I am exteremly happy that I have the remote control the cable box and receiver volume withought having to press the "cable" or "aux" button to switch between, I would llike to see if there is an answer to the problem. I currently have gone with the remote set up to turn everything on and just turn the receiver off by hand (or by its own remote).
