Receiver recommendation for MartinLogan 4i and 8i speakers.
277 Views 3 Replies 3 Participants Last post by  Craig Peer
Hey all!
I'm highly interested in using MartinLogan 4i's for my fronts and surrounds. Additionally, I plan to use the 8i for my center. I know that these are 4ohm speakers. Does anyone have a receiver recommendation?
Potential Setup:
Front L/R: MartinLogin 4i's
Center: MartinLogan 8i
Rear L/R: MartinLogan 4i's
Sub: ?
Receiver: ?
1 - 4 of 4 Posts
Probably need budget constraints and requirements. Are you future proofing or just dipping your toes in the water?
However, w/o knowing the aforementioned, and off the top of my head, IMHO.
Receivers: Marantz SR, Denon X series, Yamaha
Subs: SVS 12" (good bang for the $), ML 12". If you have the finances and the room, I would highly recommend 2 subs.
Disclaimer: Be careful out there, you could take the wrong pill and fall down the HT rabbit hole.
I'm sure others will offer their thoughts. Hope this helps and good luck.
Peace and blessings,
Azeke
See less See more
Hey there!
I'm looking to keep the receiver under $1,000. I'm open to future proofing, but it's not necessary. I don't plan on changing my TV for at least five years, and it does not have HDMI 2.1 ports.
Regarding the sub, I'm looking for a 10" or smaller to ensure that it doesn't have a large footprint.
I'll be dedicating another room for theater purposes where I have my wife's permission for floor standing speaking and hugggeee subs. Haha
Hey there!
A Denon X2700H will be under $1K. Small subs -
1000 Pro Series Subwoofers – SVS (svsound.com)
SVS 3000 Micro Subwoofer | Dual Active 8-inch Drivers | 800 watt RMS (svsound.com)
1 - 4 of 4 Posts
