Status
Not open for further replies.
1 - 3 of 3 Posts
Buying something soon in the inexpensive range $3-500. Anything with IR remote that would work thru walls?
Ummm... IR stands for "infrared" as in "light"
It doesn't go through walls.;)
You can use a repeater though. Try smarthome.com
Yeah, I agree with Ron.
Don't look for rf (radio frequency) remotes with that low of a budget. Buy a good receiver with a standard ir remote and use an rf repeater. There are versions at Circuit City, Best Buy and Radio Shack for around $50 or so.
1 - 3 of 3 Posts
Status
