My recession buster kits from madisound came in last week. This will be my first attempt at DIY speakers. I've read that the baffle-step correction is pretty minimal on these, so I'm going to try them in-wall and see how they sound. I'll be using these for an ultra-budget home theater in the kid's game room. The front 3 will be behind a DIY acoustically transparent screen, so I'm not too worried about aesthetics. I mainly just want to keep them up and away from any flying toys or rogue light saber swings.
Here's my plan. The baffle will be the only thing exposed, and will be the same dimensions as the plan call for (7"X13"). The box will extend down further into the stud bay of the wall to make up for the volume lost by the narrow depth. The baffle will overhang the rest of the box by a 1/4" all around, so it should just slide in to install. The box inside the wall will be about 3.5" deep, and 25.5" long. Basically the box will look like a periscope:
Attachment 148138
I had some 1/2" MDF laying around, and I want to maximize the internal volume, so I'm using that for the boxes. The baffles will be 3/4". Got started on the boxes today, here's what I've got so far:
Attachment 148139
Attachment 148138
Attachment 148139
