Status
Not open for further replies.
1 - 6 of 6 Posts
I just recently bought a Speaker Setup (Athena Point 5 MKII's) and should be recieving them either today or tomorrow and I'm looking for a reciever to power them. I've been looking at the Pio VSX-1015TX but I've heard mixed things about it (Lacking in the Music Department?). I would like to stay under $500 and want atleast 3 Optical Inputs and would like to have 3 Component. Up-Conversion isn't a factor because other than my Dreamcast (Which I barely use) Nothing would be hooked up through Composite Video/S-Video at all. Its use is probably going to be chopped up evenly between Gaming/Music/Movies so it needs to accell in all fields. Other than the Pio VSX-1015 here's a short list of others I've been looking into.
Kenwood VR-9070 (I know it only has 2 Optical Inputs but everything else is there)
Onkyo TX-SR702 (Only 2 Component Inputs, Over $500 but heard decent things about its sound)
Onkyo TX-SR602S (Good value and great inputs but afraid it won't have enough to power my speakers)
Pioneer VSX-815 (Cheaper than the 1015 but its not THX and don't know if it would be a signifficent downgrade in AQ)
Yamaha HTR-5860 (Only 2 Componenet)
JVC RXD702 (Over budget and I would have to wait a couple more weeks for it)
I'm definetley open to other recievers than the one's I listed. ALL help would be apreciated as I am pretty much an Audio noob.
The Onkyo TX-SR602S would have no problem feeding your speakers. If you have a huge room, those speakers may be too small.
Pioneer VSX-815, don't worry about THX certification if the rest of your system is not THX certified.
I would also look at the Denon AVR-1906 (only has two optical inputs)
and the Harman Kardon AVR335 (only two component)
Discussion Starter · #3 ·
The room is the smallest of the house (10x11 at Best) so Its not very big at all. About the Denon, To me it looks like 3 Optical (1 Front, 2 Rear) along with 2 Coaxial and 1 Optical Out. The Price tag looks a little high ($550 is the cheapest I could find).
I was in your same situation and ended up with the Yamaha 5860 and I am loving it. I am an XM guy, so the built in tuner played a part. One thing I rarely read about on the 1015 that killed the deal for me is the front 'drop down' panel to get to key features. I would basically have to have that trap door open all the time, no way.
Try Crutchfield.com or tweeter.com- they both have the 1905 for around $450.
1 - 6 of 6 Posts
Status
