I am trying to use conjunction with display changer in order to automatically change the refresh rate of your screen to match the fps of the video playing. I am running a nvidia 9300IGPU and windows 7 but I am using mpc-hc to play my files which are mostly 24p and PDVD7 for blu ray. I have reclock and display changer installed and came across the below runevent.vbs here but have been having trouble getting it to work properly. I am in the UK PAL region and my tv supports 50/60/24 Hz. I have asked on the reclock forum but have not been able to solve.
The issue is that reclock stays yellow and says cannot synch this CINEMA video to your video hardware please set your monitor refresh near a multiple of 24. If I change the refresh rate manually to 24 reclock flashes green and red. If I then exit the video the refresh rate does get changed back to the default refresh rate by the script. I tested that dc can change it to 24 and it can.
To confuse matters I did get it to work briefly. I got a message bad driver support change hardware access method so under the video settings , hardware interface i changed the option to direct 3d low and behold the script worked and refrsh rate changed!!! However, I tried changing the seting back to auto and it stopped working again as expected. BUT when I changed back to Dirsct3d it doesn't start working again and either does setting it to directdraw. :bang:
Could it be my Nvidia drivers causing an issue?
I am using the vbs script from this thread: http://www.avsforum.com/avs-vb/showt...2#post16480802
