Status
Not open for further replies.
1 - 2 of 2 Posts
Hi,
I'm having some problems with Reclock (particularly v1.1 and V1.0)
My system is set up as a HTPC using WinXP sp1 (all updates), Athlon 2000, SB Live 5.1, Geforce2 MX440 and 256meg ram. I am using Zoom Player and Sonic Cinemaster Video and WinDVD Audio.
The problem is when I start a dvd with Reclock on 5-6 times out of ten the program wil either freeze at startup or play a few seconds and then freeze. I have tried all sorts of configurations but with no luck.
Can anyone help with some advice or assistance as the dvd's are only smooth with it!
Hi,
Think you will find that it happens to a lot of people, me included,
try disabling V sync, this helped on mine
Steve
1 - 2 of 2 Posts
Status
