I'm currently using this TV in my man cave (sitting 8-10ft from screen) for PC gaming, watching movies and sports, and occasional console gaming with a capable but modest 5.1 sound system. There is a fairly significant amount of light coming into the room during the day, as there are 2 windows behind the couch facing the screen and another window on the side. All viewing is done directly in front of the screen.
I bought this TV new approximately 3 years ago from Best Buy for just under $5k and could use it to replace a 7 year old plasma elsewhere in the house. I absolutely love the set with the Darbee and it's served me well as my PC gaming monitor for 1080p. I haven't kept up with display technology since purchasing it, but since my PC is capable of running anything I throw at it at a high frame rate with max settings in 4k, I'm interested in an upgrade. I really enjoy having the large screen, so I don't want to sacrifice too much in the way of size.
Considering all of these factors in my viewing, what would you folks recommend? I'd like to stay around the same price point if possible. Is there anything out there that will provide me with a visible improvement with a higher refresh rate?
Lastly, is there a Darbee Darblet for 4k, or another device that I should add in between my AVR and whatever new TV you recommend?
