1 - 1 of 1 Posts
So I had to move to a rental home, and my once hidden rack is out in the open. The fans on the crown amp are so loud I couldn't recalibrate my Onkyo receiver.
I know the fans are 80mm x 25mm. What I don't know is if there is a specific voltage or connector that is required. Looking for one that is quiet and has blue LEDs.
I also want to tap into the crown fan power lines and power two more 80 or 120mm fans. I want to emplace these on top of my Onkyo 707. It's already been to the shop once and gets very hot after only an hour. Does anyone see any issues with tapping into this power source? It would be ideal since the fans would be easily switched on.
1 - 1 of 1 Posts
