1 - 16 of 16 Posts
Discussion Starter · #1 · (Edited)
I'm upgrading my home theatre speakers to these:
Klipsch RF-7 II Front
Klipsch RC-64 II Center
Klipsch RS-62 II Surrounds
I'll generally just use the set for home theatre, and very rarely for any music. I've got the Pioneer VSX-LX70 amp ( http://www.pioneer.eu/uk/products/ar...LX70/page.html ).
I'm still looking into the subwoofer however. I've currently got the Paradigm PDR-12 (12", 110W RMS, 330W peak) and wonder if anyone could recommend a good sub to go with the new speakers?
My budget would be somewhere between $400 and $1000, and ideally would like to stick to a 12" or smaller. I intend one day on having my own home theatre room, so I can't really give any room dimensions sorry, but it wouldn't be massive (6 seats maybe). I like to listen at high volumes for the occasional big movie once every few weeks, but a lot of the time it'll be pretty standard volume. Music isn't really something they'd be used for.
Any suggestions would be great. Thanks!
Banned
Huge speakers and a small sub do not make any sense. Chances are your RF7 could do bass more authoritatively than any small subwoofer. A much better idea would have been to get a couple good subs and some bookshelf speakers fronts. Probably the best you can do in your range is a SVS SB2000, but I don't think it would even be better than your RF-7s. You might think about getting a SVS PB2000 and crossing it over at a very low point, becuase it is unlikely to outperform your RF-7s with respect to mid and upper bass.
Premium Member
LostBoyNZ said:
... I'll generally just use the set for home theatre, and very rarely for any music. ...
I'm still looking into the subwoofer however. ...
Get as good a sub as you can now and you won't be in a hurry to upgrade it later. If space isn't an issue, don't limit yourself to a 12" sub - there's no need to.
IMO, options include:
- SVS PB-2000 ($799, shipped, with free return shipping within 45 days)
- PSA XV15se ($899, shipped)
- HSU VTF-15H (currently on sale for $839 + $143 shipping = $982, shipped)
Discussion Starter · #4 ·
Ah that's very interesting to know! Apologies, I'm really quite new to all this.
The RF-7 II goes down to 30Hz ± 3dB, and so I thought I'd need something to go much lower, like below 20Hz. In particular for movies? But do you mean smaller subs, while they go lower than the RF-7 II's they don't do it very well? Sorry, I'm not too sure what exactly the difference is there.
I'll have a look into the SVS SB2000 too, and as you say if I get that I can cut it off where the RF-7 II's take over better.
Discussion Starter · #5 ·
The PSA XV15se looks very interesting too! I like the idea of not being in a hurry to upgrade it later too, I'd prefer to buy once and get it right for many, many years.
75" Samsung Q80R QLED, Denon AVR3300, Revel F36, C25, W263, FV15HP x 2, ATV4K, Sony Blu Ray, Harmony
Don't get a small, cheap sealed sub for movies, you will be disappointed.
1) Rythmik FV15HP B stock $1250ish
2)PSA XV15se $899
3)Hsu VTF15 $982 on sale as indicated.
Those would be the top three imo near $1k
Banned
+1. Speaker size and power requirements go up as frequency goes down. If you want to keep up with the four tens you have the minimum you'd get away with is two fifteen loaded ported subs. Less than that isn't worth bothering with.
Discussion Starter · #8 ·
Interesting to see more recommendations :)
Living in New Zealand it's difficult to listen to most subwoofers. So I have to go off what people recommend.
Dual 15" ported subs helps point me in the direction though. Other than that, when comparing subs without listening, what should I pay attention to?
Two PSA XV 15's is a good option. I have the RF 7's and ran them as small with a 15 in. sub and a SVS 12 in. cylinder sub and that was pretty good. Two 15 in. subs would have been better for movies. I used the system mainly for music so the real low end stuff was not a priority.
Premium Member
If you're interested you can guy the PSA XV15's from http://www.powersoundaudio.com/blogs/news/12363965-deep-hz-audio
They're located in Australia but sell to New Zealand too.
Discussion Starter · #11 ·
I think I'll go with that, the two PSA XV 15's :)
When you say you ran the RF 7's as small, did you find that was better than setting a lower cut off frequency on the subs?
Discussion Starter · #12 ·
2)PSA XV15se $899
The SVS pc12+ outlet at $1049 should also be included in that list.
I like running the RF 7's with the small setting in the AVR. They are like monster satellites speakers. I like the subs doing what they do best, play the low bass for music and movies. Just turn the sub xo all the way up and set the xo in the avr between 50-100 depending on your system and room.
Discussion Starter · #15 ·
Thanks everyone! I've decided to go for the dual PSA XV15's.
This whole set will be a big upgrade over my old Wharfedale Atlantic AT-400 speakers and such. Looking forward to giving them a go. I'm not sure how long sea shipments take, but I assume about a two months or so.
I'll try setting them with the RF 7's as you've described :) Cheers!
How do you determine the subwoofer requirement based on the main speakers? In this case, two 15" subs are needed to keep up with two speakers that each have two 10" woofers. What would be the requirement if instead of two 10" woofers in the mains there were two 6.5" woofers? What if the bookshelf contains only a single woofer instead of two? And does having a center or not having a center or a having a different center from L/R not make a difference in determining subs, as in this case the RC-64 II is a different configuration from the RF-7 II?
1 - 16 of 16 Posts
