  • Take part in a short activity and share your valuable opinion on new design concepts for AVSForum! >>> Click Here
recommendation for balck ceiling paint
4229 Views 11 Replies 11 Participants Last post by  TMcG
hi
can somebody recommend a particular black paint for theater room ceiling. Did not know there were that there were that many different black colors.
1 - 12 of 12 Posts
I used SW 6258 Tricorn Black Paint. We used it for the ceiling. The rest covered with different fabrics. Just finishing the theater so I am attaching a sample picture here. I thought it turned out to be really good. This paint has an LRV rating of 2. Hope this helps.
See less See more
Behr Flat Mouse Ears Black If they search Mouse Ears...it will come Mouse Ears Mickey Disney. Very black
This thread should do the trick. Rosco Supersaturated velour black was my pick and I couldn't be happier.
http://www.avsforum.com/t/1218000/the-blackest-most-flat-paint-period
http://www.rosco.com/scenic/supersaturated.cfm
Originally Posted by Jeff in Canada  /t/1518600/recommendation-for-balck-ceiling-paint#post_24377495
this.
What
What I used
Without question the Rosco Supersaturated is the blackest paint, but it requires a bit of thinning to make it more viscous and usable. Doubtful you'll notice much of a difference between the Rosco and the Mouse Ears in a darkened room, though.
Here is my wall now with a flat black paint.
See less See more
I won't claim it's better than what others have recommended, but I am very happy with the Valspar "Cracked Pepper" color. It seems very black, and covers well.
If you happen to prefer shopping at Lowe's for some reason, it's something to consider.
See less See more
Originally Posted by AirBenji  /t/1518600/recommendation-for-balck-ceiling-paint#post_24379976
How much did you thin it out? I have seen recommendations all over the place. I am picking up the paint tomorrow and want to get the ceiling painted asap!
Jeffrey
See less See more
What color paint is this for walls and trim?
The blackest paint available is Rosco Supersaturated Velour Black #6003. It's what's used in professional stage productions and theaters. Valspar and others are far more available and less costly options, but hey...you asked the question.
1 - 12 of 12 Posts
