Originally Posted by geodon005 /forum/post/0
I am at work, so I have not had a chance to test this on my own . . . what is the "clear difference in volume" that you hear? Which setting creates the higher volume?
I didn't play with it long, but from what I remember I was listening to dialog from the center speaker, and when I switched between MIN and STD there was no difference, but when I moved it to MAX the dialog got much louder.
There's definitely a lot of confusion surrounding this. First off, the text in the manual says that this selects the amount of dynamic range compression. So logically you would think MAX meant max compression. However maybe the description is being taken too literally here and MAX really does mean max dynamic range. Normally I would think so but the report from toenail makes me wonder.
Also it is interesting that the manual specifically says to use MAX for feature films. So that seems to make it pretty clear that they mean MAX = max dynamic range not max dynamic compression. However just because that's what they meant to write doesn't mean that's how it actually works...
Now that I have a better understanding of what to listen for I'm going to try finding some passages that go from dialog to something loud, then go back and forth in the different modes to see which gives me the greatest difference between the two and I'll assume that settings is for the max dynamic range.
Another thing to consider is that the receiver defaulted to the MAX settings. I would be very odd if Yamaha did this when this setting really meant max compression (so this is another thing in favor of max meaning max range not max compression).
