1 - 2 of 2 Posts
· Registered
I need help.
I currently have a set of JBL NSP1 5 speakers and I need to add 2 rear surrounds. They will be on the wall and have to be white!!
I see the Polk RM6751 as possible option
How about the "Yamaha NS-AW150W 2-Way"? They are listed as indoor/outdoor.
My budget is about $100 for the pair. Any recommendations?
Thanks in advance
· Registered
Originally Posted by khaled12 /forum/post/15501846
I need help.
Thanks in advance
I'll probably get blasted for this, but don't worry. In your range, even a single driver, all purpose would do. Frequency range is not as important as a smooth response and dispersion. A tonal balance with your other speakers would be a plus....but for a $100 bucks don't limit yourself to speakers by the same manufacturer. Tonal balance to me just means that the response curves are similar. You may end up with one better than your mains. I would prefer wall mounts too and any of those would do as inwalls restrict dispersion and flexibility.
1 - 2 of 2 Posts
