Hello everyone,
I've got two UTV's, the Sony W60 will not record two shows at once. Everytime, I attempt to do so, it gives me a conflict. The RCA which is in a different room works fine. I immediately suspected that a tuner was bad, so checked my PIP, which is working, but I noticed it has a ton of pixelation.
After checking my transponders, I found that I couldn't lock on the even transponders but only on tuner 1. Suspecting a cabling issue, I swapped my cables and my problem moved to tuner 2.
Could this be a problem with my multi-switch? How would I know? If it is why wouldn't it be happening on the other UTV?
My multiswitch is a non powered radio shack model. Do any of you have any recommendations for a powered model?
Thanks in advance for your help.
RJ
RJ
