Status
Not open for further replies.
1 - 2 of 2 Posts
So I have successfully done single drive upgrade to 80 Gbyte Maxtor 5400rpm.
I have backed up the replaytv partition so I now want to use the 30 G Quantum drive in my win 98 SE PC.
The thing that I am not sure about is what I have to do to prepare the drive for use in win 98, and also what tools to use.
For example can I just hook it up and format from windows?
Do I need to get a tool from Quantum and do low level format?
I may want to make this a bootable drive and copy my current drive windows install over, how do I do that?
TIA
You must delete the old partitions in DOS using FDISK, then recreate a new one using FDISK again. After that, the format can be done in DOS or Windows.
1 - 2 of 2 Posts
Status
