Be very careful about the modifications that you make to your HVAC system if you don't understand airflow and how your HVAC system works. You can reduce it's efficiency, reduce it's life, damage it and even kill your system.
There is one phrase that he used in that article that has me concerned. He said that there was a sucking sound when he closed his new door. This suggests to me that there was a problem with his system and he has made it worse. I think he has caused a situation that WILL damage his HVAC system and cause premature failure.
It appears that he has a heat pump. If this is the case then he hasn't created a dangerous condition that could put his life in danger. If he used gas for heat then he probably would have created a dangerous condition if what he did wasn't done properly.
Of coarse if his noise is only the noise that the unit makes under normal conditions when installed properly then the mods he did are perfectly fine. The sucking sound he hears when closing the door suggests that the unit has bad airflow and he made it worse. Insufficient airflow will damage an HVAC system.
Most noise from your HVAC system is usually due to poor airflow. Poor airflow is typically due to improper installation of the ducts. Many HVAC installers install ducts that are too small according to manual D. Manual D is the bible for residential duct design. It has standards for allowable air velocity for the different duct materials. I rarely go into a house and find that those standards have been followed. If followed the air noise coming from the HVAC system is substantially less.
I get comments all the time about how much quieter my installs are compared to what they had. They also find that they are more comfortable through out the house.
DO NOT make any modifications to your HVAC system unless you run it by a qualified (licensed) person that can look at your system. There are many things that have to be considered that you don't know about. Even small mods that you might think are insignificant can cause problems. NEVER enclose your indoor unit unless you know that it is safe to do so.
