My AVR displays everything in "reference level" increments (-15DB, for example, is 15 below reference level)..
My question is, how on earth can the AVR know what the level of the input signal is going to be? So, in my situation, I have a HTPC connected via HDMI on an ATI 5XXX series card. (let's use the example of music, but it stands for movies as well). In Winamp, I have a volume slider. I also have Winamp specific sliders (that can boost the level by 12 DB, IIRC). Finally, I have a Windows master volume slider..
If I have the AVR set to 0DB (reference level), what do I need to set the PC at to input the right "amount" of signal to drive "real" 0DB output. For example, I could set the AVR to 0DB, but then set the master volume in Windows to 5%, that's certainly NOT reference level. I'm assuming that it would be everything (except Winamp boosts) set to 100% (WinAmp and Windows Master Volume)?
It's hard when you have 3 (or 4) volume controls between the source and your speakers; I'm just not sure what I'm actually outputting compared to reference level..
Thx!
Thx!
