Status
Not open for further replies.
1 - 2 of 2 Posts
I recently purchased a refurbished 4508 from replay.com. I have had it set up now for 3 days, and it has already frozen twice (where it was in the middle of recording something, froze and had to restart). Did I get a dud? I have another 4508 that has never frozen. Is there something I can to do to fix the problem, or should I take advantage of the 90-day warranty to get a different machine?
Thanks in advance for any suggestions.
Are the 2 units running the same software? Hit 411, then Replay Zone to check the software version. If they aren't, hit 273-RZ then option 7.
Other than that making sure they have good ventilation, you might just have a bad unit.
1 - 2 of 2 Posts
Status
