721 - 740 of 1076 Posts
How long before we see 5050 refurbs? I feel sorta stupid for missing out on the $2699 deal for the 5050 but now I've been waiting so long I'm thinking I should hold out for an EVEN BETTER deal, haha.
Premium Member
I would think it would be another year when it gets closer to a new model coming out. The 5050 is still rather new. Now I have seen some people say that Epson has sent them a 5050 in exchange of the 5040 if they have had a lot of problems. The 5050 may go on sale around Christmas if you can wait.
Hi, Rick...My 5040UB refurb showed up yesterday. This thing is a Monster! Unbelievable blacks, brightness and sharpness...so much more than my old HC3020. Some examples are attached. I couldn't be happier. Looks like I got a good one!
Does look good.....nice upgrade! ;) .........curious, light controlled room?
Unfortunately; no. Right in the middle of the space is a HUGE skylight that I have to hire a pro to deal with (it's 20 feet up), so my viewing is currently limited to dark hours. It's on the "list" though...
Do we have any idea if Epson will ever have these refurbished units in Stock again?
Unfortunately missed out when they did have stock. I called but got the standard "we have no idea, keep checking back on the website" answer from the service rep.
Worried I may have missed out for good considering they sold a bunch of them over the summer and I would guess they aren't producing them anymore as they have moved on to the 5050ub.
Sent from my SM-N960U using Tapatalk
They will definitely come back in stock. When I got mine in June, I had to wait two or three weeks to snag one. Sometimes they will stock just a few at a time, at odd hours of the day. Then after getting mine, they were out of stock for a solid month I think.
So just keep tabs on this thread, or have the Epson page loaded in your browser and just refresh once in a while.
A quick question re the Canadian bulb rebate. Did you guys send the UPC from the box? The form PDF calls for one despite the US form (same promo id) mentioning nothing about it.
TIA
Welp, lost at refurb roulette game. Just finished a new 2.35:1 accoustically transparent screen theater build and now projector is shutting itself down. Started happening at the 87 hour mark. Back it goes. Was working fine up until this point.
Edit: Spoke to Epson. Apparently the latest gen Apple TV 4K streamer I just introduced into my system is the culprit. It's sending an ir blast when in sleep mode that is shutting off the projector. Workaround is to go into settings-general and change sleep mode to never. Also need to turn off the control receiver function. Problem appears to be solved.
TIA
Nope...I don't think they have that offer for Canadians. I didn't get one. I bought a refurb just over a week ago, and it came with the projector, a remote with batteries and a power cord.
Quick question for any 5040UB owners....
I purchased a refurb just over a week ago, and while the projector throws a beautiful image, every once in awhile, the picture suddenly and unexpectedly goes black for a few seconds, and the comes back. This happens on both broadcast and Bluray. Before I call Epson, has anyone else had this happen?
Hasn't happened to me. Could be an HDMI issue. Have tried swapping to a different cable?
The lamp rebate is in fact valid for Canadians. I got a lamp recently from submitting mine, although it took 2.5 months.
Here is the link for the Canadian form, make sure you fill it out. That’s a $250 lamp for free!
https://mediaserver.goepson.com/ImConvServlet/imconv/ce3dd60dad6ee638a45c6e0f630e40db522c4fba/original?assetDescr=Home%20Cinema%205040UB%20&%205040UBe%20(EA1051)%20MIR%20(EN).pdf
Kinda hard to do. When we renovated, I installed a 25 foot HDMI cable that goes from my AV receiver through the wall, under the floor, and up a pillar to where the projector is hanging. (This happened about 6 years ago when I bought my first projector, and HC3020, and it was fine, however when I got my 5040UB, the "blanking" started happening). It'll be a pain to change the cable, but I can get a newer one that is 16 Gbit and 4K compatible, and if it stops the problem, I guess I have to find a way to replace the existing one. I saw a 25 footer the other day that was 4K compatible, and it was just 40 bucks Canadian, so it may be worth a try. I guess I'll call Epson Tech Support before I do, and see what they say. I have a feeling that you are right, though.
Thanks for the help.
Well, I guess I missed it. The projector was purchased the first week of September.
You will be asked to check with another HDMI cable, HDMI source and to try both ports, you might want to do that first (with a shorter cable and/or a fireTV stick or something and get your existing setup out of the equation) to rule out a defective HDMI port.
Hi Billy....yep had this same thing happen with my new 4030 and then started inquiring about a new HDMI cable...but before replacing the 50' cable, which worked fine for the last few years before swapping projectors, I cleaned all the contacts on the HDMI cables and devices...presto problem went away. :)
Now the 5040 is a different beast but if your only transmitting 1080p hopefully yours is a similar issue, I'd give a try.
https://www.avsforum.com/forum/68-digital-projectors-under-3-000-usd-msrp/3059392-40-plus-foot-hdmi-cables-projector-2.html#post57903652
Hi Guys......
Just a follow....before investing in new cables in a situation where all was well but then things start to act up.....I figured that if my audio connections, RCA, balanced and speaker spades need periodic cleaning to remove any oxidization to improve signal flow the tiny HDMI pins are definitely candidates for a bit of house cleaning.
Having on hand some Credit Card cleaning cards in my shop I thought I'd give my cables and connections a once over by just using the corner ....by delicately inserting the moistened corner of the card in the opening of the cable or component just give a gentle sweeps back and forth a few times, I imagine one could also use a thicker porous business card with the corner dipped in alcohol or invest in some blotter paper.
Needless to say any errant dropouts appear to have stopped. (for now)
If you find that its indeed your HDMI cable that needs replacement, and that its a tough job to change the inwall HDMI cable frequently, it would be a good idea to go forward one time with an optical HDMI cable to future proof yourself. Just a suggestion.
