Status
Not open for further replies.
1 - 4 of 4 Posts
Hi All,
I'm quite sure this can't be done but I thought I would ask here in anycase. I have the YAMAHA Home Theatre Speaker system NS-P220. Now, I haven't bought a receiver yet. My HTPC has a Hercules Fortissmo II. Would it be possible for me to hook up these speakers to the sound card directly (I have no idea how to do this!) without the need of a receiver? Might be a really stupid question but for my HTPC I was trying to use my computer to do all the processing!
Harish.
Harish,
You're going to need some sort of amplification to use them (poweramps or receiver) since they aren't self powered (except the sub) acording to the yamaha page.
A lot of people in the Revo thread are trying to use their HTPC's to do all the processing. You will need an amplifier of some sort, and not to start a war but poweramp(s) might be overkill for your setup.
You might want to check out the Revo thread.
http://www.avsforum.com/avs-vb/showt...hreadid=187531
1 - 4 of 4 Posts
Status
