1 - 2 of 2 Posts
I'm shopping for a new TV. I'm looking at TV reviews and specs but data on remote control specs is hard to find.
Remote control features like discreet on/off/input and response time are an important factor in my buying decision.
Picture quality is important but lack of discreet power is a deal breaker.
I'm seriously looking at the Samsung LED and Plasma TVs and want to be sure they have discrete controls before I buy.
You might want to consider contacting Samsung directly on that question. They may be able to direct your inquiry to their technical services staff and, ultimately, provide you with the answer you're looking for. Good luck!
1 - 2 of 2 Posts
