Now Available: Tech Talk Podcast with Scott Wilkinson, Episode 19 Click here for details.
Originally posted by oneway (other than having one powered on, the other powered off)? |
Originally posted by oneway Thanks docmcse; I will try [Menu] -> 243 [Zones] tonight and report back. Maybe this could be added to the FAQ (unless I missed it..). |
Press Menu on your remote
Choose Setup.
Press 243 + Replay Zones on your remote
Originally posted by docmcse Oneway, this is not the "normal" 2-4-3+Zones menu, this one only shows up after you have run setup (menu-setup, to get to the usual setup menu). Then while on that screen press the 2-4-3+Zones sequence to see this menu. |
Originally posted by jhomewood The reason that the toggle method is not desirable is the delay in units turning on and off, (it does not happen instantaniously)... |
Originally posted by Wasatch Rider By changing the code on the replay unit you have only solved half of the equation. Now you need a remote that sends that code to the replay unit. The only way I know of to do that is reprogam the remote via a jp1 connector. Back to the search engine. |
Originally posted by Jeff D Rob or anyone else.... ReplayEric's comments about the system codes says it resets on a reboot, has there been any changes with the replay software to support the same system code through reboots? With the 5k constant reboots this would be a worthless feature, no? |
