Status
Not open for further replies.
1 - 5 of 5 Posts
hey everyone i just bought a philips pronto tsu2000
with out spending tons of money how can i control my theater lights.. theres only 4 lights in the room on the wall on the same switch
from what i understand i would neeed
http://www.x10.com/products/x10_ir543.htm
that to control the lights with the remote and
http://www.x10.com/products/x10_ws12a.htm
for the new switch
for the switch it says
Rated at 120VAC/60Hz. 500W (incandescent only). 500 Watts maximum load, 40 Watts minimum. Dimmable through X10 controllers.Includes both white and ivory rocker plates. UL and CSA approved..
now the bulbs total is 4 and each is 60 watts.. will this switch be ok to run those 4 bulbs?? if anyone else has an idea for me to try please let me know
also im adding some halogen (spelling) type lights in the ceiling they go in the ceiling.. is this my best bet or what does one of those lutron http://www.lutron.com/grafikeye/grx2000.html grafic eye things what i need?? thanks for all of your help
I use X10 switches and I use a Pronto to control them.
On one switch I have six bulbs at 60 watts each. No problem.
You can use those wall switches and they will work fine for basic controls that you will have to do individually, but if you want to create scenes for your HT, you will have to get the Switch-link switches. Those are expensive at about $85 each.
However they work great and are still much cheaper than the other hard wired systems.
If you have any other questions you can to to Remote Central and check out the X10 section there.
Discussion Starter · #4 ·
Originally posted by RetinalBurnOut
I think that trying to control lightning, even remotely, could be hazardous to your health. Best to unplug the TV and go hide.
huh?? maybe you should take less crack ;) its bad for you
Look into the SwitchLinc light controls at smarthome.com
1 - 5 of 5 Posts
Status
