Status
Not open for further replies.
1 - 2 of 2 Posts
I'm looking for a universal remote. I have an Akai DVD player and an Outlaw receiver and I can't find a remote that has pre-defined codes for these two components.
Will a learning remote be able to pick up the codes from the Akai and Outlaw remotes? I'm leaning toward a MX-500, but I'm also curious if a OneforAll can learn these codes.
they both should be able to handle them. The problem with OFA remotes is the amount of programmable memory. But with a JP1 cable for more info go to www.hifi-remote.com you can replace some of the configured memory and so memory is not a big problem any more
1 - 2 of 2 Posts
Status
