Status
Not open for further replies.
1 - 8 of 8 Posts
hello again. for the past month or so, my UTV (RCA DWD490RE) remote will not hold onto the TV mapping I set for it. not the biggest problem in the world, but wondering if there is anything I can do to help it.
basically after i issue some UTV command, like hitting my shows button or something, I'll loose the capability to control the TV (like volume). after that I have to hold down TV and enter 1002 (for my sony TV) and then i'm back to normal until I do another UTV command.
any thoughts on what's up with that? this UTV/remote is a lot newer than my other one, only about 6 months old.
thanks again for any suggestions. you guys have been a HUGE help to me for all issues in the past.
take care, marc
Well, I'm happy to report that Watching's suggestion works. The settings are retained, and I'm once again able to control my remote control. Not that I'm a control freak or anything.
1 - 8 of 8 Posts
Status
