Status
Not open for further replies.
1 - 1 of 1 Posts
I bought an HD unit and I am very happy with it. Its a F-38310 RCA unit with the newer upgraded tube. The TV works great, but I am having problems with the remote. The problem is the remote seems not to work near florescent lights. It sometimes worked and sometimes it wouldn't work. Its very aggravating I must say. Now, it doesn't even work at all regardless of florescent, or any light source near it. So, as per the instructions, I cleared it by removing the batteries and held the ONE button down for 60 sec. and put the batteries back and it will not work.Is there a service man type clear for the remote? The light flickers faster than a similar DirecTV Remote. I remember the led light staying lit and not flickering when it worked properly. What is the correct way the clear the
Remote? Any help would be very much appreciated.
TIA:confused:
1 - 1 of 1 Posts
Status
