1 - 3 of 3 Posts
i was having sound probs with my player and somehow have changed some remote settings!!!! OMEONE HELPPP!!!! everytime i press anything on the remote it says DR 2 i read some info in the manual i press hdd and dvd buttons on player and it says DR OFF but then still the remote dont work>> how do i sort this out????? is there a way to sort this out or how do i perform a factory reset on the dvd player????
Don't own a Toshiba, but with the Panasonic models you press and hold down the power button, then press 1 or 2 for either remote code, and then press Enter. Until someone with a Tosh shows up, try that.
1 - 3 of 3 Posts
