1 - 6 of 6 Posts
I built my first HTPC, and it's near completion. The setup is:
1. MB: Gigabyte GA-E7AUM-DS2H
2. Case: LIAN LI Black Aluminum PC-C37B Micro ATX Media Center / HTPC Case
3. OS: WinXP 32 bit, Media Center edition
Other components:
1. AVR: Sony STR-DG720
2. TV: Samsung LN52A650
3. Cable: Verizon FIOS
I bought a LOGITECH HARMONY 550 remote, and programmed it with the AVR, TV and cable. It works very well.
Now I need to find a remote solution for my HTPC. Not only do I want to control my HTPC with the Harmony 550, I also want wireless (IR?) keyboard/mouse as well.
So, is there an IR receiver that can interact with Harmony 550, and also wireless keyboard/mouse? Please give me your suggestions.
Thanks in advance for your help.
Brandon
Other components:
Brandon
There are a couple ways to go about this.
1: Buy a wireless keyboard and wireless ir receiver for an MCE remote. I personally use 3 different IR receivers, 1 for keyboard, 1 for remote, and one for turning the PC on/off IMon.
2: Buy a wireless IR keyboard and program the harmony to emulate keyboard equivalent remote commands. I'm just not sure if the harmony can learn key combos...
Discussion Starter · #4 ·
Option 2 sounds like the solution I am looking for. Thanks for your help, PanamaMike.
an extra 2c for you
I've used a Bluetooth and RF for keyboard/mouse combos, and liked the Logitech MX3200 RF and Logitech MX5500 bluetooth the best. They simply work and work well, and have lots of useful programmable buttons. I especially like the MX3200's Zoom features on both the keyboard & mouse for HTPC use if the text isn't readable. I've used the receiver that Morphyne recommended with great results with a lower end harmony (I think it was 670?), and currently use another brand variant with my harmony ONE. They usually have combo deals for 5$ off that remote if you have another piece for hardware to purchase.
Personally, I think it would be easier and more effective to simply purchase the unit Morphyne linked and throw away the remote. IR Wireless keyboard/mouse sets are few and far between, meaning you have to settle for what you can find. Even if you are going for a simple 'look' with only one receiver showing, I've used both of those keyboard/mouse combos from 15 feet with the receiver plugged into a rear pc port- no hiccups. No need for line of sight with RF or BT. I guess I'm saying I don't see the benefit of using solution 2 "trying to make the harmony emulate keyboard equivalent controls" when perfectly good inexpensive remote solutions exist. You just tell the harmony to be an MCE remote and you're set.
1 - 6 of 6 Posts
